I am coming from using File Explorer on Windows and was wondering what are all the interesting keyboard shortcuts available for use.
For example in windows - Switch Tabs - Alt + Tab.
Ones I am curious about :
Move file from left pane to right pane [??]
Open highlighted folder on right pane [??]
Is there documentation regarding all the possible keyboard shortcuts ?
Like in Firefox, Emacs and Vim ?
Do the shortcuts from Total Commander carry into oMega ?
There is a lot more documentation for that as it much older software.
best regards,
Is there documentation for a list of all shortcuts ?
Re: Is there documentation for a list of all shortcuts ?
To display the list of hotkeys, you can simply press F1.
In Help, hotkeys are immediately displayed and are divided into dozens of sections.
You can also open the same Help online:
https://pylonos.com/Content/omega/help/ ... s_base.htm
To open highlighted folder in the left pane: Ctrl+Left
More can be viewed here:
https://pylonos.com/Content/omega/help/ ... yncpan.htm
F6 for moving (F5 for copying)Move file from left pane to right pane
Ctrl+RightOpen highlighted folder on right pane
