Hi there,
Is there any way to show the metadata in a file, e.g. in a PDF or docx/doc, in some kind of info panel?
Basically all the data you can see if you right-click on a file and select Properties.
Regards,
Michael
See file Properties in info panel?
Re: See file Properties in info panel?
Unfortunately, the feature is currently unavailable. However, we appreciate your valuable suggestions! We will definitely consider them while working on future versions.
Currently, apart from accessing the Properties menu, you can also:
Press Alt+Enter.
Another option is to hover the mouse pointer over the desired file. The information you need may appear in a hint.
Press Alt+Enter.
