Higlight file/s just downloaded opening related folder
buietto
Post by buietto »
Hello to all !
had a look in setting but cant find a way to "go " to the latest file/s just downloaded instead of the complete list within the folder
I mean :
when I have to download a file opening the download folder I have to search it in list ( alphabetically ) I would have the possibility to see the file highlighted "at a glance"
Any suggest ?
Thank You !
Maurizio
Lord Vendreth
Re: Higlight file/s just downloaded opening related folder
Post by Lord Vendreth »
Hello buietto,
you can either sort the files by date in descending order or look at which files have a red dot in front of the file name :)
German language translator and Forum Moderator for oMega Commander
German or English, I will try to resolve your concerns to the best of my knowledge and conscience :D
Deutsch oder Englisch, Eure Anliegen versuche ich nach bestem Wissen und Gewissen gerne zu lösen ;)
Hello!
You can use the following hotkeys:
Alt+4 - Sort file list by date
For a quick jump, without sorting the list:
Alt+Home - Go to the latest by modification date file
Alt+PageUp - Go to the nearest earlier file
Alt+PageDown - Go to the nearest older file
Alt+End - Go to the oldest by modification date file
To highlight all recently downloaded files.
Click on one of the recently downloaded files, and press:
Ctrl+Alt+"+" - Select files with the same mark
Other hotkeys can be viewed here:
https://pylonos.com/Content/omega/help/ ... lelist.htm
https://pylonos.com/Content/omega/help/ ... stmisc.htm
https://pylonos.com/Content/omega/help/ ... ilesel.htm
buietto
Post by buietto »
HI !
sorry for delay
..thank you very much for your/s replies
Now its ok ! ..to be honest i'm not so familiar with hotkeys so have to learn about
thx again
regards !!
