I use every day this command for creating a folder called "Rapport"
Is there any possibility to create an icon within a ribbon with a command doing that automatically (adding the name as a fixed parameter ton the existing icon/function in the ribbon) in the folder I am viewing ?
if yes, how could this be achieved ?
Thanks for you help
Stéphane
Command F7 new folder
Joomla! 1 to 3, Linux, OSX, Windows 1.0 to 10
Please forgive me my English as it is not my mother language, I am French
Re: Command F7 new folder
Add a button to the ribbon.
In Tools Designer specify for it:
Command: mkdir
Parameters: Rapport (or any other name)
In Window dropdown: Select two options: Hide the window; Run in Cmd-window (close on completion)
Command: mkdir
Works perfectly !
You've made my day !
I will gain a lot of time creating my reports !
Many, many thanks for your appreciated help !
Have a nice day,
Stéphane
Works perfectly !
Have a nice day,
Stéphane
