Folder Icon Update on change
steph38
Post by steph38 »
I use a little software to change, on the fly, the icon of folders (gives me the possibility to quickly see the state of the folder, done, ongoing etc.)
Unfortunately, when I change the icon, it is not displayed right away in OC (but it is in explorer). When I quit and reopen OC the icon is updated...
As it worked perfectly on the version 2 of OC, maybe I have to enable it somewhere in the settings, but I cannot figure out where...
Many thanks for your help,
Stéphane
Joomla! 1 to 3, Linux, OSX, Windows 1.0 to 10
Please forgive me my English as it is not my mother language, I am French
Re: Folder Icon Update on change
Thank you, we'll take that into account.
For now as a workaround you can refresh icons without leaving the folder by double-clicking on the icon load indicator.
You can see it by extending the info bar (under the file list) to three lines.
Take a look at the screenshot:
Icons indicator.png (1.62 KiB) Viewed 233014 times
steph38
Post by steph38 »
Hello,
it works like a charm ! And is fine for me as workaround.
Many thanks,
Stéphane
