As you can see in the picture below, Korean Letter is not working in Quick Search.
If this is a bug, Please fix it.
Thanks.
plztrial4me
- quick search.png (36.63 KiB) Viewed 623771 times
Re: Korean Letter is not working in Quick Search.
Hmm, that's a tricky question. We'll try to troubleshoot the problem, learning Korean along the way.
Meanwhile, which soft-keyboard do you use? Is it Microsoft IME or Microsoft Old Hangul?
plztrial4me
I'm using Microsoft IME on Windows 10.oMega Support wrote:Hmm, that's a tricky question. We'll try to troubleshoot the problem, learning Korean along the way.
Thanks, we are working on resolving the issue!
plztrial4me
Thanks for your quick response.oMega Support wrote:Thanks, we are working on resolving the issue!
If you want, I can run various tests on Korean Letter for quick search.
Please contact me if you need my help.
oMega Commander is the best!
It's going to take some time to add support here for 3- and 4-bytes (UTF-8) Unicode characters, which includes Korean characters.
The fix will be bundled with other improvements in the next release.
Meanwhile for reporting the problem we'd like to award you with a license for oMega Commander. We'll contact you personally over email to confirm the desired name on the license.
Thanks!
Thanks!
