Korean Letter is not working in Quick Search.
Please report only one bug per message!
plztrial4me
Post by plztrial4me »
As you can see in the picture below, Korean Letter is not working in Quick Search.
If this is a bug, Please fix it.
Thanks.
quick search.png (36.63 KiB) Viewed 623767 times
Re: Korean Letter is not working in Quick Search.
Hmm, that's a tricky question. We'll try to troubleshoot the problem, learning Korean along the way.
Meanwhile, which soft-keyboard do you use? Is it Microsoft IME or Microsoft Old Hangul?
plztrial4me
oMega Support wrote:Hmm, that's a tricky question. We'll try to troubleshoot the problem, learning Korean along the way.
I'm using Microsoft IME on Windows 10.
Thanks, we are working on resolving the issue!
plztrial4me
oMega Support wrote:Thanks, we are working on resolving the issue!
Thanks for your quick response.
If you want, I can run various tests on Korean Letter for quick search.
Please contact me if you need my help.
oMega Commander is the best!
It's going to take some time to add support here for 3- and 4-bytes (UTF-8) Unicode characters, which includes Korean characters.
The fix will be bundled with other improvements in the next release.
Meanwhile for reporting the problem we'd like to award you with a license for oMega Commander. We'll contact you personally over email to confirm the desired name on the license.
Thanks!
