MixExplorer like pinned folder.
not_enough_pixels
In MixExlorer (Android App) you can pin folders when visiting crowded directories. Would it be possible to do it in oMega Commander ?
Re: MixExplorer like pinned folder.
In oMega Commander, there are many ways to quickly and conveniently work with a variety of folders. Here are some options and small tips:
Bookmarks
Shift+Alt+A - add/remove bookmark. Alt+A - list bookmarks.
https://pylonos.com/omega/features/en#bookmarks
https://pylonos.com/Content/omega/help/ ... _flags.htm
Hot List
Open the required folder. Shift+Ctrl+D - add to the menu. Ctrl+D - select from a menu.
https://pylonos.com/omega/features/en#hotlist
https://pylonos.com/Content/omega/help/ ... otlist.htm
Ribbons
Drag the required folder on a ribbon in the application header or one of your own ribbons. If you hold Alt while dragging, the button will be assigned a name.
In case of large count of such folders you can group them into dropdowns.
https://pylonos.com/omega/features/en#ribbons
https://pylonos.com/Content/omega/help/ ... common.htm
Folder Tabs
Open the required folder. Shift+Ctrl+Digit - add a tab, Ctrl+Digit - navigate to that tab.
Hold Alt while clicking a tab to open the folder in the opposite panel.
https://pylonos.com/omega/features/en#foldertabs
https://pylonos.com/omega/faq/en#ShowTabs
https://pylonos.com/Content/omega/help/ ... olders.htm
Tabs of internal windows
Ctrl+N - Open new window of file panel
Shift+Ctrl+N - Open new temporary window of file panel
Ctrl+Tab - Switch to another window
Ctrl+W - Close window
https://pylonos.com/Content/omega/help/ ... edwins.htm
https://pylonos.com/Content/omega/help/ ... s_wins.htm
Navigation history
If you have already been in the folder before, use Alt+Down to open the navigation history, and Alt+Left or Alt+Right to navigate backwards or forwards.
https://pylonos.com/omega/features/en#history
https://pylonos.com/Content/omega/help/ ... v_hist.htm
Tree
The most frequently used folders can be dragged to the "Quick Access" item in the Tree.
Shift+Tab - Open Tree (Navigation Pane)
https://pylonos.com/Content/omega/help/ ... s_tree.htm
.lnk
If you have an .lnk-file for a folder, select the .lnk-file and press
Ctrl+Left or Right, which opens the folder on the opposite panel.
Network drive button
Sometimes the root "\" Network location takes forever to read. You can assign a default network path to open instead of the root.
To do that, navigate to the required location, right-click on the [Network \] drive button and click 'Set current folder as the default path of the drive "\"' in the context menu.
Bookmarks
Hot List
Ribbons
Folder Tabs
Navigation history
Tree
.lnk
