Hello!
oMega 3.0.47 (5687) often forgets window size after minimize and restore.
Running unter Windows 10 20H2 with 2x 4k monitors attached
1. start oMega
2. resize window
3. minimize
4. restore
window is way larger than set in step 2
But not always! I have currently 3 instance of oMega open and only one shows this behaviour.
oMega changes window size
Re: oMega changes window size
So far we couldn't reproduce the issue. Could you share additional details:
1) Initially, on oMega start, is the application window in the Full Screen mode?
2) How do you change the window size?
5) Does that happen on the main or secondary monitor? Any particular secondary monitor, e.g. left/right only or top/bottom only (in case negative coordinates affect that)?
6) Any patterns?
Thank you!
oMega Support.
- When in Full Screen mode click on Restore Down window button.
- When in Full Screen mode double click on the window title.
- When not in Full Screen mode drag window borders.
- Click the Minimize window button.
- Click the application button in the Taskbar.
6) Any patterns?
Thank you!
oMega Support.
Thanks for replying.
I am currently away from this setup but will try to reproduce it once I am back.
