oMega changes window size
Please report only one bug per message!
mister
Post by mister »
Hello!
oMega 3.0.47 (5687) often forgets window size after minimize and restore.
Running unter Windows 10 20H2 with 2x 4k monitors attached
1. start oMega
2. resize window
3. minimize
4. restore
window is way larger than set in step 2
But not always! I have currently 3 instance of oMega open and only one shows this behaviour.
Re: oMega changes window size
So far we couldn't reproduce the issue. Could you share additional details:
1) Initially, on oMega start, is the application window in the Full Screen mode?
2) How do you change the window size?
  • When in Full Screen mode click on Restore Down window button.
  • When in Full Screen mode double click on the window title.
  • When not in Full Screen mode drag window borders.
3) How do you minimize the window?
  • Click the Minimize window button.
  • Click the application button in the Taskbar.
4) How much bigger does the window become? If possible, please post or send to support@pylonos.com screenshots before minimization and after expansion.
5) Does that happen on the main or secondary monitor? Any particular secondary monitor, e.g. left/right only or top/bottom only (in case negative coordinates affect that)?
6) Any patterns?
Thank you!
oMega Support.
mister
Post by mister »
Thanks for replying.
I am currently away from this setup but will try to reproduce it once I am back.
