Delete File at networkshare
Please report only one bug per message!
gremlin
Post by gremlin »
Hy,
when I delete a file at a network share (smb) the file would delete, but the view shows it until i do a reload.
Maybe a bug, or i don´t find any solution to enable a refresh after delete...
Thanks
Steven
Lord Vendreth
Re: Delete File at networkshare
Post by Lord Vendreth »
Unfortunately, I can not understand this case. For me, deleting including removing the file from the view works both with and without mapped drives via SMB.
EDIT: I found an article about network settings regarding SMB. Maybe the problem is with the caching of the files. Have a look at this article...
Windows clients will not refresh Linux samba file locally if reading file at intervals <= 10 seconds
German language translator and Forum Moderator for oMega Commander
German or English, I will try to resolve your concerns to the best of my knowledge and conscience :D
Deutsch oder Englisch, Eure Anliegen versuche ich nach bestem Wissen und Gewissen gerne zu lösen ;)
gremlin
Post by gremlin »
Hy,
I had a file at my synology NAS.
When I delete the file with Omega Commander then I see the file still at the filelist.
If I open the directory with windows explorer it´s deleted, also with totalcommander.
If I refresh (strg+r) with omega commander the filelist update and don´t show the file.
When I use windows explorer or totalcommander and I delete a file, it´s disappear from the filelist.
This case only at synology shares and only with omega commander.
At local drives everything works good.
Lord Vendreth
Hi gremlin,
Have a look at the settings for automatic updating of the list. I myself have a QNAP NAS and everything works without problems.
1. open settings
2. search for "refresh"
3. check settings
gremlin
Post by gremlin »
Hy,
I had the same settings already.
But the problem still there....
Maybe Windows 11 ?
Try to remove this checkbox, which is in the screenshots above:
"Watch for creation, deletion, and renaming of files and update files list"
Maybe this will help.
gremlin
Post by gremlin »
Yes, thank you. Now it works...
