Tree sync?
radukn
Tree sync?
Post by radukn »
Greetings! Can I have tree sync with the folder I am currently in? In the main panel I keep changing the current folder, but the tree stay without any change. I would like to be in sync.
Thank you!
Lord Vendreth
Re: Tree sync?
Post by Lord Vendreth »
Hi radukn,
you can activate the treeview-feature "Automatically expand to the open folder. This should be what you looking for :)
German language translator and Forum Moderator for oMega Commander
German or English, I will try to resolve your concerns to the best of my knowledge and conscience :D
Deutsch oder Englisch, Eure Anliegen versuche ich nach bestem Wissen und Gewissen gerne zu lösen ;)
radukn
Re: Tree sync?
Post by radukn »
This is great. Thank you!
The next one: in columns (in detailed view) can I have last modified date and creation date, like în MS Explorer? I could not find such an option.
Re: Tree sync?
Date column shows the Modified date. Creation Date isn't available for a column. But you can get creation date by pressing Alt+Enter on a file.
