I want to create a new thread in the "General" category of the forum, but that don't work.
So I start here the thread and you can move it if you want
Ok... sometimes it is difficult to understand a function of the application. For correct translation it make sense to understand what happens if I use/change a setting and see where it should happens. One or two screenshots to the correct place in the application can help to go on.
Here is my question:
Where I have to look for "Drag files using blank spaces" / "Rubber-band selection"? How I have to use these function?
Greets,
Dierk
German languagetranslator and Forum Moderator for oMega Commander
German or English, I will try to resolve your concerns to the best of my knowledge and conscience
Deutsch oder Englisch, Eure Anliegen versuche ich nach bestem Wissen und Gewissen gerne zu lösen
If you select "Drag files using blank space (instead of selecting)", you don't need to click on the active element to drag it. You can grab an empty space in the list.
If you select " Rubber-band selection (instead of dragging)", a rectangular selection will start from an empty space.
I've found a section which was not translated to english.
Sounds like in the applications's subfolder Docs (e.g. C:\Program Files\oMega Commander3\Docs) you have a file called oMegaInetDemos (de).lst, which most likely is a copy of oMegaInetDemos (ru).lst. Please delete the file.
Otherwise check if file oMegaInetDemos.lst contains non-English text.
These are descriptions of demo videos on YouTube. Since they are in English or Russian, we think no need to translate their descriptions.
What does this function do? I've tried some things, but I see always the trees.
Translation could be a little misleading at this point.
The option is for systems with several monitors.
See https://pylonos.com/omega/features/en#tree
The last image in the slider shows how to extract a Tree into an external window.
If the tree is open in an external window, it automatically hides when switching to another application.
