Rename Multiple Files
plztrial4me
Post by plztrial4me »
Does oMeage have no "Rename Multiple Files" feature yet?
Lord Vendreth
Re: Rename Multiple Files
Post by Lord Vendreth »
Mark multiple files and press F6 or Shift + F6. There you can use the rename mask :)
German language translator and Forum Moderator for oMega Commander
German or English, I will try to resolve your concerns to the best of my knowledge and conscience :D
Deutsch oder Englisch, Eure Anliegen versuche ich nach bestem Wissen und Gewissen gerne zu lösen ;)
plztrial4me
Lord Vendreth wrote:Mark multiple files and press F6 or Shift + F6. There you can use the rename mask :)
Thanks for your reply. It's what I want! :D
a minor tip. After pressing F5 / F6 / Shift+F6 you can immediately press the Down key to see the mask, which can be changed.
If you did renames previously, pressing Down one more time shows the last entered mask.
