Is there a command to go the drive?
Posted: 27 Apr 2020 01:20
by plztrial4me
Is there a command for hotkey to go the drive like pressing the button on the drive selector?
(Go to the working directory of the drive)
Re: Is there a command to go the drive?
Posted: 27 Apr 2020 05:34
by Lord Vendreth
Hi plztrial4me...
you can navigate direct to any folder of your choice :)
Posted: 28 Apr 2020 00:46
It may be better to use command /Folder(Current,"C:\")
Then the drive will be open in the active file list.
But if on drive opening you need to start with the last active folder, press:
Alt+F1 / F2, then the drive button.
Posted: 28 Apr 2020 05:13
by Lord Vendreth
oMega Support wrote:It may be better to use command /Folder(Current,"C:\")
Yes, that is much better. My picture shows only 1 of 4 different possibilities:
  • Current
  • Left
  • Right
  • Opposite
The possibility to set these parameters, is very nice :D
Posted: 28 Apr 2020 05:46
by plztrial4me
Thanks for all the replies.
But I didn't meant to that.
/Folder(Current,"C:\") command goes to C drive's root directory.
But pressing the C drive button on the drive selector goes to C drive's working directory.
I wanna to go to C drive's working directory for hotkey using command if it is possible.
If there is no such command, I suggest make it. :D
Posted: 29 Apr 2020 01:07
Thank you for the suggestion, we'll keep it in mind.
Currently e.g. for switching to the work folder of drive C on the left panel you can press in sequence Alt + F1, C
