Tree sync?
Posted: 31 Oct 2020 11:17
by radukn
Greetings! Can I have tree sync with the folder I am currently in? In the main panel I keep changing the current folder, but the tree stay without any change. I would like to be in sync.
Thank you!
Re: Tree sync?
Posted: 31 Oct 2020 11:42
by Lord Vendreth
Hi radukn,
you can activate the treeview-feature "Automatically expand to the open folder. This should be what you looking for :)
Re: Tree sync?
Posted: 31 Oct 2020 18:09
by radukn
This is great. Thank you!
The next one: in columns (in detailed view) can I have last modified date and creation date, like în MS Explorer? I could not find such an option.
Re: Tree sync?
Posted: 31 Oct 2020 19:40
Date column shows the Modified date. Creation Date isn't available for a column. But you can get creation date by pressing Alt+Enter on a file.
